John Deere Z930A running only on 1 Cyl
Jeweler
I have a Z930A and been a great mower has 490 hours and now is running only on 1 cylinder replace the simple spark plugs and it didn't fix. Any recommendations would greatly be appreciated. Thanks
Scrubcadet10
Moderator
Staff member
More than likely your ignition coil, which produces spark. Just follow the spark plug wire and you'll find it. And clean out any debris ( if any)
Jeweler
Thank you I will check it out and see if there is anything around it.
