I have a John Deere x300 side discharge 42" deck. Have been using mulching blades. Looking to find out what the part number is for the complete bagging unit for this model? or is there more than one part needed for whole unit? Thank you
According to the JD website, it looks as though there are two baggers available depending on which deck you have. If you have the 42" mulching deck, here it is..
The link in my second post shows a number of SKU21679. I don't know if that's all you'll need or if it's only the bagger section, but maybe it'll get you started.
The reason you can not pull up the bagger on the parts website, is because that is a whole good. The attachment has to be ordered thru a different internal site.
As far as options, there is only one. It is the 7 bu. bagger for your 42" deck. It will require a set of high lift blades which do not come with the kit. Hope this helps.
