Nunda Mustard
- Mar 27, 2015
- 1
Looking to repair steering problem on my John Deere stx 38 yet need schematics just in case there is more to it than replacing the bushing. Any advise would be helpful. Thanks
May as well replace the pinion and sector gear, that's never been greased, while it's apart.
Lubing the steering gears is another topic all together. Some say to lube the gears, others say don't. Third opinion is to use graphite. The opinion is using grease will reduce the wear in the gears, but with all the dust and grime of mowing the grease will collect the grit and turn it into sandpaper. What's your thoughts?
Steering problem ?
Won't turn left ?
won't turn right ?
goes right when you turn left ?
Wobbles?
Lots of steering problems
