I have a LX188 and the engine is still shutting down. I first started with shutting down and the oil light would come on. Replaced a blown fuse on
the ignition board and I though that fixed the problem. I ran it cutting grass for about 15 minutes and everything was fine. Shut it off checked fluids
restarted and it ran about a minute or two then shut down. Re started and it shuts down but no oil light comes on? I am thinking its something electrical
maybe the igniter box or the ignition board? Is there any way of testing the board or the igniter box? I hate to replace one or the other if not needed
they are pretty costly. Some ones thoughts or answers will be helpful. edlkll
