alternative browser .
Sep 10, 2013 #1
D
debsav
john Deere lt166 wont start turns over but not starting. I replaced the spark plug and but teaspoon of gas in spark plug hole did not start.
Sep 10, 2013 #2
reynoldston
you need to test for spark other then just replacing the spark plug.
Sep 10, 2013 #3
Fish
Find the model numbers off of the engine and post them for help, thanks
Sep 10, 2013 #4
davbell22602
I have JD LT166 46in with the 16hp vtwin briggs.
Sep 10, 2013 #5
D
debsav
I checked for a spark this evening and there appears to be none. Now what do I do?
Sep 11, 2013 #6
D
debsav
There was no spark so I looked for a wiring problem and found a connector that was popped out of its hole. i pushed it back in and then tried it again and it started. pretty simple fix. The wire must have been shorting out on the metal.
Thanks for your help.
