John Deere LT 150 mower will not start
ZKaren
I have a John Deere LT 150 150B505432 with a kohler CV15S. 41618 engine that will not start. It has spark and the fuel pump has been replaced. New gas lines new gas filter changed the air filter. Cleaned out the gas tank. New gas gap. Gas lines and gas cap were changed because they were very sticky from the gas over the years. Carburetor was cleaned also. The gas is going to the carburetor and it cranks but will not start. It will not start with starting fluid either. What am I missing?
Sounds like the problem is at the carburetor. It can be a physical or electrical problem.
Verify the fuel solenoid pintle is not stuck and make sure the electrical connector has not spread the pins and not providing power
Someone did put an aftermarket carburetor on it. But this carburetor doesn’t have the fuel solenoid there are no wires coming in to hook up.
Have you checked the safety switches? Or, are you trying to start it with the blade/pto engaged? Is the parking brake on? If it won’t light off with starting fluid then it has: too weak a spark, a bad spark plug, the timing is off, or the spark is grounding out. Disconnect the kill wire from the coil and see if it lights off. If it does, find the wire that is grounding the spark. Likely to be a safety switch malfunction, or operator error.
Fuel for just one of the four you need.
1.Air
2.Spark AT the correct time
3.Fuel
4.Enough compression to run.
Where exactly did you spray starting fluid at or into?
