john Deere JS46
joem154
I cannot start my John Deere JS46. I prime by utting gas into the carb and then it will run until that gas seems to run out... then it stops. The gas tank is full with fresh gas.
Joe
Do you have the primer bulb on it ??
Shoot me your model number of the engine....... I think I know your engine that you have..
joem154
There is no primer bulb (sadly). I put gas in the carb and it ran until that fuel ran out. I don't have a "model" number, just what info I gave. I disasmebled the carb/reassembled it, cleaning it out … but no luck :(
Ok........ what side of the engine is the carb on when you are behind the mower ???? The left side of the engine or the right side ??
Ok when you had the carb apart did you have a white piece in the middle of it when you took the bowl off ??
Is it a metal carb or a plastic carb ??
The model number should be next to the carb on that metal plate..........
joem154
It was a plastic float inside the bulb. There was no model number on the carb :( I assume that's where I would have seen it (not found)
Yep all the newer carbs have plastic floats.... I was referring to a something else..... Is the carb itself a plastic carb or the metal carb ???
The model number of the engine should be next to the carb on a metal plate on the front of the engine...... Or on the valve cover..........If you have the engine I am thinking of ~!~!
Let us know Mon Ami ~!~!
