Hello
I got a problem with my John Deere F510 Kawasaki PA420A.
It starts perfect when the engine are cold but when it get warm I can't start it again before it cooled down.
Also it sometimes die when mowing, last time it died and backfired at the same time, it also lack power but only when the blade are engaged.
I have cleaned the carb and changed the fuelfilter so no problem there, and the fuel line is not hot.
A compression test on warm engine is 150psi.
If I spray some fuel or engine start in the cylinder it will not start.
What do you think about coil issue ?
Sorry for my bad english, it is not so good but I hope you understand
