I have a Kawasaki FH531 engine in my John Deere 325 lawn tractor. I tore it down to replace all the seals and gaskets due to oil leaks. I reassembled the engine and set the governor up like it says in the manual. Throttle wide open, governor shaft counter clockwise and governor arm counter clockwise. Engine starts and goes full rpm. Took the crank cover off to check the governor shaft and everything appears fine. Put it back together and it worked but did not reach a high rpm when throttled up. Tried to adjust governor a little and now it will only go full rpm again. Can't get it govern at all.
