When engine start.......starter wheel will not disengage the flywheel.....what could be the problem
H Heavyduty053 Member Joined Jul 13, 2015 Threads 6 Messages 11 Jul 13, 2015 / JD Z425 Zero turn #1 When engine start.......starter wheel will not disengage the flywheel.....what could be the problem
M Mikel1 Well-Known Member Joined Jul 21, 2013 Threads 10 Messages 897 Jul 13, 2015 / JD Z425 Zero turn #2 I take it you mean the starter pinion gear won't disengage. A problem in the Bendix. You could try lightly greasing the pinion gear shaft. If that doesn't work then rebuild or replace starter.
