Twigs
Re: the local libaryRe: JD Snow Blower 1032 Oil leak
Yes on the Tecumseh 10 hp...Hmm flywheel puller..have to see about that I'm hoping my friend who knows more about small engine can help me..I know old cars better...Yes on the guess where the leak is..I thought maybe I over filled the oil when I did the oil change and that was why the oil was coming out..but when I check the dip stick there was just a trace of oil on the stick...it is kind of strange I don't see the oil leak when running the engine..I only happen to see it due to the electric started coming loose. Then I saw a mist of oil coming out of the hole where the electric started fits into the flywheel.
Now I live in Wallkill, NY south of Kingston about 25 miles...
Is it a Tecumseh engine? The seal is under the flywheel which it would help to have a flywheel puller. To me its easy but I have done this job before . If you have never did anything like this before maybe visit the local library and read a book on small engine repair would help you. Getting out the old seal can be a little tricky sometimes.. Another thing is are we just making a guess on this oil leak as to what is leaking?? I would say the first thing to do is find out where the oil is coming from. To do this clean up all the old oil and then run the engine because I have found that a oil leak can travel.
Never heard of Mt. Marion so I will have to look it up.
