JD LA120 deck vibration
PMW096866
Just replaced blade belt and installed new blades. Blades balanced good and new belt correctly routed. Blade engagement normal, but deck vibration seems more than before. Worn spindles? There is slight play in spindles but does not seem excessive. I may reinstall old belt and blades to try and compare. Thoughts ?
