Engine Jd 826 snowblower
Mwh0428
I have a jd 826 snowblower and a family friend rebuilt the carb on it it has a tecumseh h80 snow king but it will only run on full to 3/4 choke. dose anybody know what's wrong?
Look back in the carb... float level or something is causing it to be too lean,... May be an air leak between the carb and the intake port... :smile:KennyV
Could it be the the valves? And if so how do I check them. I ran it last night so my bro could go to work and I had a rough idle unless under a load and I had a blue flame coming out of the muffler. but it runs like a top under load.
