JD 245 start issue
tatersquad
I have a 245 with a 14hp kawasaki. It will not start. With an in-line spark tester there is little to no spark even with grounding wires removed. Gap is correct on plug and coil. New coil, ignition module, spark plug.
Looking for suggestions.
DaveTN
What about fuel? Could be fuel starvation. I’ve noticed spark is harder
to see these days, esp outside.
tatersquad
Pretty sure it's not fuel related as I have tried running it on carb cleaner with no luck. There should be spark but there is light to none using both an in-line tester and pulling plug testing outside the engine.
