Fuel JD 114 Dying
moonds
Will be mowing along fine and mower will just die. Will crank just not getting fuel. Fuel filter fine. Wait about an hour and it starts fine. Any suggestions ?
Get an inline plug tester .
Put it on the morew so you can see the neon tube and go mow.
When the engine is dying check for the orange glow ( indicating you have a spark ).
If it glows while the engine is dying you have a fuel supply problem.
Blocked outlet in fuel tank
air lock in fuel tank.
Faulty fuel pump
