Issues Matching New Carburetor
blamz
I'm trying to match my carb from a 124T02-0120-B1 to one of Amazon. I can't get an exact match on components. I need one with a plastic choke shaft that has gears and a plastic throttle shaft. It seems all carbs have one, of the same choke/throttle shafts but not both. The closest I can get to the original is the correct geared choke shaft but the throttle shaft of the new ones are metal with a small handle.
Is this type compatible with my engine? 1st photo is my existing choke.
