 - Nov 29, 2014
- Threads
 - 65
 - 24,995
On the frame between the engine & the fuel tank / seat depending upon the model
Clutch bearings are not replaceable so it is new clutch time .
They are also not cheap
start a new thread about "need a replacement toro Time-master clutch "
You should get a lot of good information
When you take it off double check that it has been assembled correctly
Down here they all have Warner clutches fitted and on Warners ( don't know about others ) you can fit them with the rotor on the wrong side of the brake magnets .
And FWIW I use a long stud when fitting electric clutches to take the weight while I align the key ways
Some times I luck them strait away the other 99% it isa 20 minute battle to get them on .
Polish the PTO shaft and apply some copper anti seize .
On some you can grind away the bearing retaining tabs, fir a new bearing then MIG a couple of dabs back on to hold it in place .
As a workshop I do not do this but I do have a few clutches sitting in the "might get repaired box ".
Again a few You Tube vids with bods showing it being done , but you need to be a dab hand with the welder so you don't cook the dust seals in the bearing
If you are lucky you might be able to pop the seals , clean out the old grease & put some fresh Bentonite ( brown stuff that stinks ) grease in there but don't overdo it because the balls have to roll in the race not slide over them.
