- Sep 24, 2017
- Threads
- 276
- 6,720
The bolt is 1/4" x 20. So it would be advisable to plug this hole??Remember that when you put a bolt through there, it may push more metal particles into the combustion chamber. Also, if you can get to the rim of the hole with a rat tail file and chamfer it round, it will reduce stress and future carbon buildup. What I would worry about is, will combustion pressure pop the bolt out? I don't know what the pressure is at TDC, or how much a helicoil can hold, but that hole looks to be nearly at TDC. What's the diameter of the bolt?
Don't know. I'll measure the bolt and hole tomorrow.What is the depth of the entire bolt hole? 20 mm?
