Final post on the issue. Head gasket and a new spark plug and the mower is again running perfect. No smoke or oil coming from the oil pump. Thanks for the help and perhaps this thread will help someone else.
Your post just did help someone else I thought it might be a flywheel seal but noticed oil was just under fuel pump this John Deere has about same hours on it owner had problem with mice in the shed nest caused over heating and then head gasket caused oil leak. thanks guys big help just saved customer a lot of money.
