I am in te market for a Walk Behind Brush Mower but most are the large commercial ones and are out of my budget I have found a coupple similar in design Ardisam, Husqvarna, Powermate and Ariens. But they seem to be made out of plastic as to the guard that is underneath that is to stop debris from flying back and at you. Also seems the String that is used is not much in quality because they seem to quickly break and even one manufacturer suggests leaving the new string in water till you use it. I am looking for something to replace an old side discharge push mower for 20 arces I have and need to keep the grass / weeds down. Wondering if these are worth the money or if I need to just buy another Side Discharge push mower. Seems some like them and others don't. They suugest they can cut large stuff but when parts are made out of plastic hard to see how well it can work in a field with rocks and etc being thrown up.
Does anyone use one and which one and why??? The Ardisams seems to be the only one that has a lever to enegage the trimmer head the others don't. Never seen one and the the few don't have much of information on them.
Thanks,
Newaygp1
Thanks,
Newaygp1
