As in sprayed the outside down removing grass, oil and bugs off? Gutted to the last part cleaning everything in the way?
Most likely the carb is dirty internally. Fuel tank and gas can might be full of trash as well. Fuel line could be delaminated internally. Any fuel filter could be plugged. Never had the valves adjusted. Cooling fins totally neglected. If the engine is 7-10 years old, probably never de-carboned per the engine manual.
