Hi
Hope this might be the right forum for this:
This 4 stroke engine comes from an old swiss military 12V emergency generator. I am trying to identify engine manufacturer & type.
What I really need is a to replace ignition components, maybe change to electronic coil.
The problem is there are no identification plates on the engine or any components I found yet. My guess is that it could be a 1960-70`s Briggs & stratton...
What I know
- Engine uses imperial nuts / bolts (The rest of generator setup is metric.)
- Cylindre diameter: ~60mm (2.36 inch)
- Stroke: ~38mm (1.5 inch)
- Flywheel diameter: ~146mm (5.75 inch)
- Generator is 360W (~0.5hp)
Any ideas?
br
Marcus
What I know
Any ideas?
br
Marcus
