Stainless69
I have a Toro zero turn with a Kawasaki FR651V 22hp on it. It's been a great mower for the last four years but started popping on me the last time I mowed with it. I was about 75% the way through mowing my yard when it started popping and losing power. I could disengage the blade and it seemed to rev back up and run normal. Then after I started mowing again, it would eventually start popping again. It has good fuel in it, plugs look good and air filter is clean. I think one of the coils may be going bad after it warms up. I've taken both coils off and measured them. One of the coils measures 15.66 and the other measures 19.30. I think I am doing this correctly. The one coil is on the upper limits of the spec and this is at room temperature. I've read that these can be tell tell signs of coils that are going bad and act up during operation. If I'm reading the spec correctly, it says 20 is the top.
I'm attaching an image of the spec as listed and a youtube video of the problem as it's happening.
https://www.youtube.com/watch?v=FgZY85Q4SlE&feature=youtu.be
Thanks for any help.
