Frankendixon3014
Is it possible to convert a Dixon 3014 cone drive into a hydrostat drive?? Ive already done an engine swap with a 429, when i was adjusting the cones i broke the eye rod end, part# 7786.. please help.
So 2 hydro wheel motors mounted to the frame with a hydro pump powered by the pto wont work??
What I was saying is if you put two motors attached to the frame it would raise the rear end 6 inches. How will you level the deck?
He only needs a One inch hole for the shaft to go threw the frame. Bolt the motor to the side of the frame. Not the bottom.
A hydro motor is only 4"x4"
