JCS49
- Mar 27, 2021
- 1
- 2
I just purchased a used Simplicity Prestige garden tractor with the suspension with shock absorbers front and rear. On rougher ground the transmission surges and I can feel the control pedal go up and down slightly. I suspect that since the frame goes up and down and the speed control mechanism is mounted on the tractor frame and the transmission is mounted on the swing arms that do not move relative to the frame the control arm gets shifted slightly causing the surging. If that is correct ,how is this remedied? Thanks, jcs.
