hi all are you supposed to fill the hydro oil tanks? and if so what with? thanks
S sss Active Member Joined Aug 22, 2011 Threads 24 Messages 94 Dec 21, 2011 / hydro's #1 hi all are you supposed to fill the hydro oil tanks? and if so what with? thanks
K KennyV Lawn Pro Joined May 5, 2010 Threads 26 Messages 5,447 Dec 21, 2011 / hydro's #2 The hydro's on what...? Most all use a good grade multi-viscosity Synthetic Motor oil... In the 5w 50 range... you can't go wrong.... :smile:KennyV
R rander Member Joined May 6, 2010 Threads 0 Messages 14 Dec 22, 2011 / hydro's #3 Most hydro systems on mowers do well with Mobil 1 5W-50.
