Hustler Raptor SDX no start
goosemasterkl
My uncles Hustler Raptor 60" cut with Kawasaki engine won't start using the key but when I jumper across the 2 big post on the Solenoid it will crank that way. Does that mean the solenoid is bad? Thanks in advance for anyone who replies.
No, it doesn't mean that. Could be though. You need to check the safety switches and the ignition switch. There's a wire from the ignition to the solenoid that needs to get voltage when the key goes to start. Make sure you're engaging the seat switch when you check the ignition. If it gets power, but the starter doesn't turn, solenoid is suspect. If it doesn't, safety switches, fuse, or ignition switch. Provide model/serial number for the mower so we can look up the wiring diagram.
Here's the model and serial number of the mower. Thanks for your help.
