Husqvarna Z248F (967336701) deck belt issues
Spindle pulley: 5/8" ID
5 3/16" OD
7/8" height
Part# 532173436
Rotary # 7180
Idler Pulley: 11/16" ID
5 7/8" OD
1 15/16" height
Part# 539132728
Rotary # 14100
3 of each
I figured out the issue and I am an idiot for missing it. One of the deck brackets was slightly bent. Wasn't obvious but it caused the deck to sit a little off to the side which made the belt very tight. Thanks for everyone's insight. Without that causing me to keep looking deeper I may not have found it. Thanks again.
I'm glad you figured it out. Sometimes you just need to take a break, and get some input, then get back to it.
Yep, I agree. Forrest for the trees! It helps to have several people point you into possible directions you didn't think of too. Funny thing is as soon as I got it all together and turned the blades on it died. Sounded to me like it was a safety switch but I threw a spark tester on it to make sure and verified it was losing spark. Quickly found a problem with the seat switch harness and now its fixed. Thanks again.
