Husqvarna Z 246 (no start)
atendog33
I have been trying to fix my neighbor's Husqvarna riding mower. The mower did not start last summer. He changed 3 safety switches, the starter and the solenoid, but the mower will not start. The front light will come and the hours are displayed, but that is it. I pulled on the belt and the blade is not frozen, however the engine will not start. When I turn the key to the run position, I hear a 'thump' from the solenoid, but the engine will not start.
Today I replaced the battery and the mower did not start. I decided to jump the solenoid with two screw drivers (key on run position) to see if the engine would turn over. After jumping the solenoid the engine would spin and spin, but the engine would not run. I also pulled a spark plug and I could see a spark. I believe the engine was getting gas, but still no start.
I think that he has a wire in the wrong position, but I don't know. Any ideas?
The solenoid is not polarity sensitive so either cable on any terminal is fine
If you have all the controls in the correct position & the yellow wire shows better than 10 V and the black/white wire is ground but the starter does not spin then either the starter or the solenoud is deceased.
The next test is to jump from the battery + directly to the starter
IF the starter does not spin then add a second jumper from the battery - to the engine
Starter spins = bad ground
Try using the key with the ground jumper still in place
Starter spins confirms bad ground connection
Starter does not spin = bad solenoid .
If the starter iself is bad then it can draw too much current & drop the voltage so low that the fuel shut off solenoid on the carb will not open.
atendog33
Thank you for the fast response. I jumped the red battery wire directly to the red starter wire and the engine started spinning but did not start. I checked for spark and the spark plug was sparking.
In the picture below, the vacuums line is draw rotting. I taped it over just to see if that was the problem. The mower engine will not turnover with the key. The engine will spin if it touch both red wires.
The solenoid makes a thud sound when I turn the ignition to run, but will not start.
atendog33
In the picture below, the vacuum line is dry rotting. I taped it over just to see if that was the problem. The mower engine will not turnover with the key, however, tIMG_2990.jpghe engine will spin if it touch both red wires.
So if the starter does not spin then the solenoid is shot.
The terminals burn out .
Next step is to put some fuel down the plug hole and crank the engine.
If the engine fires & runs a second or so then the ignition timing is OK
Should that be the case remove the solenoid from the carburettor
If it has 2 wires then turn the key on & off
The plunger should retract quickly every time you turn it on and snap out when you turn it off
If ithas a single wire you will need to ground it to test it.
atendog33
Ok I will try in the morning. I will keep everyone updated. Thank you all!
atendog33
I cleaned the big ground wire and it did not start. The mower will not start with the key, however, when I attempt to start the engine, the solenoid makes a thump sound.
After jumping the starter wire, the mower started and ran for 2 seconds when I sprayed starter fluid in the plug holes. I was happy to hear the engine run again, but the mower will not start with the key.
Using the volt meter I found the following...
The mower will not start with the key. I noticed the yellow wire (left lug/looking towards the rear) has 12 volts with the key on.
The black and white wire (ground - left lug) when used as a ground on the volt meter, shows 12 volts with the key off.
When I jump the yellow wire to the red starter wire, the fuse blows every time.
When I ground the black/white wire, the engine will not start with the key.
When I unplug the sensor on the big steering handle, the solenoid does not make the thump sound.
When I unplug the sensor under the seat, the solenoid will make the thump sound.
The two wire part hooked into the bottom of the carb shows 12 volts with the key on.
I think I am following what you are doing.
So pull the yellow wire & the black /white wire off the solenoid.
Turn the key on
Jump 12V to one of the small terminals on the solenoid and ground the other terminal .
Does not matter which way they are connected .
If the starter cranks the engine then the solenoid is good.
If itjst goes thump and the starter does not spin then the solenoid is bad
From what you have posted it appears that the mowers wiring is OK.
atendog33
Ok. Thank you very much. I will follow you directions when the sun comes up. Thank you again!
atendog33
Ok. The ground is good and the solenoid is new. I am sure the original problem I was having was due to a bad adjustment on safety switch (tall steering handle.)
The testing went horribly wrong and I jumped 12 volts to the wrong wire and now the mower will not make the thump sound when I turn the key. I assume that I burnt up the PTO switch. Does the PTO have an internal fuse? Will the PTO stop the mower from starting?
I followed the thin yellow wire from the solenoid to the PTO. The yellow solenoid wire goes into the PTO and comes out the PTO into a yellow wire that goes into the ignition. If I touch both of the yellow wires together, the mower starts with the key.
Again, the mower starts with key when I touch the yellow wires together. Simply, I have power going into the PTO, but no power coming from the PTO to the ignition.
Is the PTO bad? Why is the power not coming out of the PTO?
