Going on 7 years now with the K&N air filter for the Husqvarna YTH24V48. Still going strong, no problems with the filter. Clean, re-oil, done. Saved money in the long run. Annual regular oil changes, probably could get by without an oil change every year because the oil stays pretty clean towards the end of fall, but I change it anyway.
RU-0160 - Universal Clamp-On Air Filter. (You don't need the clamp, it fits perfectly!) 22-8009PK - Air Filter Wrap ("Pre-filter" Helps keep out larger debris from the filter. Suggested!)
You can look for your specific Lawn Tractor here.
You can use their search by dimension feature to find a K&N filter that fits your tractor if yours is not directly listed.
KN filters were designed for racing. High flow and catching large particles. I've seen many tests that show it lets significant dust and small particles thru. On an engine that sees a lot of dust, it is an engine killer according to many posts. Go to 18:30 for final results on air filters he tested. KN was next to dead last on catching small particles. It was first in flow. The only thing that beats it is no air cleaner at all. In other words no filter flows more air than it does, and catches less.
