Mower_blues
- Apr 5, 2019
- 1
We bought a used Husqvarna YTH24k-48 that starts ok and runs smoothly, but it only stays running if, after starting, you turn the ignition switch back to the reverse/equipment position. (position two, at top). It dies if you try to just put the switch back to regular position (position 3) after starting (position 4). Can anyone tell us what part might need fixing/replacing? Solenoid? Wires? My partner says it's fine to just run it with the switch in that (reverse/equipment) position. Any reason not to?
