I have a Husqvarna yth2348. I believe the flywheel key is sheared. Battery is fully charged and starter is engaging flywheel fine, but it rattles and backfires out of air intake when trying to start. Does anyone have videos or instructions available on how to remove the flywheel and replace the key? Also, will I need a puller or can this be done without one? Thanks.
