hi, engine number 28H707 1291-E1 00041720. Cable is attached at rear under transmission cover, the one held with 2 screws that houses gear box oil filler , etc. Cable is attached at front to acccel pedal. .When you hold down pedal, there does not appear to be any more to have, as Engine lever is fully deployed. I cannot pull it up any further. I am 77 and disabled, so not easy.. Machine does not go as fast as it did on old cable, and when you drive, foot pedal is fully depressed. Ideas please. john
