Da'Squirrel
- Dec 25, 2012
- 3
- 6
Good Day , I am new to your forum and to Zero Swing mowers , I got a Husqvarna ZTH 5225A which lost travel on one side , took it down and found it torn up a rotator in one of the pumps and sent metal thru the system ----- found a kit for $600 , which I was told will adapt , the kit included 2 pumps , 2 motors and every hose and fitting on the mower , the motors are exactly the same but the new pumps have center plates with springs and levers which is held onto a shaft that is square closest the pump and threaded on the end with a nut , where my linkage has only one arm that is held on with a pointed set screw that goes into a hole in the shaft of the pump which is flat on two sides . the newer linkage doesn't line up with my linkage -------------- my old arm with go right on the new shaft and I can lock it down with the set screw and still put a self locking nut and washer over the arm ------------------------------has anyone doone this modifaction before and have any insight
