Husqvarna drive belt help.
KroniK
Hey everyone! I have a EZ4824 model #965880401 zero turn and I need a replacement drive belt. I was cutting the other day and completely lost all driveability, no forward or reverse. Looked under the mower and noticed the belt was loose, like it stretched or something. I removed the belt and couldn’t find any wear spots or cuts, but I also couldn’t see the part number, I think it’s the original belt and it was to old to make out the numbers. I have looked at Lowe’s, tractor supply, HD and all over the internet trying to find the part number or a place to order it. I think it’s to out of date to buy one in stores. Is there another part # that will work so I can get it going again, grass is getting to tall. Thanks!
Have you tried Husqvarna ?
They made it and they have just about all of the parts lists on line.
KroniK
Searched all over their site, it’s discontinued item so they don’t have parts for it, or at least that I could find. And the only dealers are HD and Lowe’s.
They might not support it but the parts break down should still be available.
With the part number we can look up cross reference charts.
Without it all you can do is measure the length of the belt.
Kevlar belts do not stretch, they wear thinnner and because they are V shaped, get looser in the pulleys.
