Evening all.
I've got a Husqvarna 7226 zero turn mower with what I believe is the Kohler 26hp Efi engine. This mower is a hot mess and I'm trying to sort it all out.
Engine starts and runs fine for a few minutes, then starts to hunt, even at different throttles. I replaced the fuel filters, and checked rail pressure, it seems to hover just below 40psi.
If you jam it up to full throttle, it falls right on its face and dies, like it needs a bigger accelerator shot.
Also, is there any way to see what the 'brain box' is seeing/doing?
Thanks in advance
Thanks in advance
