I am definitely a novice when it comes to this sort of task, but I am a very quick study and YouTube certified on many things
. I do not give up easily when I commit to something. I tried newer fuel. It sputtered a bit like it wanted to start, but still have not got there yet. Did another complete breakdown just to see if there was anything I may have done wrong and didn't see anything. Definitely have a spark when I tested it. Did another compression check this morning and still reads low (60psi). I understand that I am using an automotive style compression tester and it could be giving a false reading because of lower displacement volume from the blower and I also know that the new piston ring needs a short break-in period to completely seal against the cylinder wall. The timing cannot be manually adjusted since it utilizes a fixed ignition module keyed directly to the crankshaft. I know that with new crankcase gasket and shaft seals, it's not a guarantee of a perfect seal being aftermarket parts, but I'm hoping they are working as intended. Next, I will be playing with carburetor adjustments to see if I get a positive reaction. Wish me luck.
