Hi, Im new the forum and I have a problem. I am having to jump my lawnmower off every time i start it. The battery is not holding charge. BUT.. while jumping it off and its connected to my Truck (after running) the gauge is reading that my mower is charging at about 8. Unhook jumper cables and the gauge immediately jumps to zero and stays are zero the entire time engine is running. Also can take it off charge after I get it cranked.(with gauge jumping back to zero). Immediatly shut it off try to start it again and absolutely nothing. I havent tried a new Batt yet. If it was the battery, with the engine running shouldnt the gauge show that its charging even if the battery is bad and not accepting a charge?
