Husquevarna YTH 2348 mower has developed a clank when deck engaged.
D-18
MY YTH 2348 Huseqevarna mower has started "clanking" and losing power in mid-size grass; it also started clanking a little when I first start the engine, with the deck disengaged. When it clanks in the taller grass, I disengage the deck and the mower regains power and the clanking stops. Help!
NOTE: the mower still mows the lower grass without the clank and the loss of power. There are no obstructions in the deck to prevent the blades from turning.
prolly got some mechanical failure with the blade spindles/belt pully.
i would inspect where the blades bolt to the spindle (threads are prolly stripped)
might have a belt pully goin bad but, you would likely experience some vibration when the deck is engaged...good luck :thumbsup:
