Huskee stuck in gear
gimmee
I have a huskee rider mower that will not move nor come out of gear. If you start it it will move OK but I can`t get it to shift out of gear.
make sure the clutch is disengaging the drive belt. if it isn't then that could be your shifting problem.
Thank You for your response.
I have performed all of that and no help.
The shifter will not move at all for any reason.
It is stuck inside the trans. it appears. Shaft will not move at all.
