 - Nov 29, 2014
 - 65
 - 24,995
If you are only going to drop the deck, then get it up high as you will be working on the underside of the mower.
No need to drain the tank, that is just to sto fuel pouring out of the tank.
If you have a trailer then drive it up on the back and chack the mower wheels & put a stand under the trailer.
Run the front wheels up the front steps, anything to give yourself hammer swinging space under there.
In most cases the steering stem will pull right out from the wheel end once the retainer under the deck is removed.
The pivot bolt No 8 in the diagram can come loose as does the guide bolt No 26
Because no home owner ever lubricates it the fan plate No 18 floggs out in the hole that the No 8 bolt goes through.
No real need to pull anything out on top of the mower it is all done from underneath.
But before you start, have a long close look at all the parts circled in the original diagram.
Note that there are 4 bushes ( no 30 ).
Look carefully at the steering stem to see if it is moving. It should rotate but not move.
All of the parts that were highlited for you should rotate but not move.
A little here, a little there and all of a sudden it is undriveable.
