Huskavarna yta 18542 will not move
Jerry Davies
Just like title says I started it up today it moved forward a few inches like it had a wet belt now it will not do nothing it's a hydro trans
Thanks
Jd
check that when the bake is released that the belt is tight
Check that the belt is on all of the pulleys
check that the idlers are in good condition and rotate freely & quietly.
Jerry Davies
The ebrake is released all belts are good when I pull the pin on the back of the mower it pushes easy and when the pin is in there is no difference
Jerry Davies
I just pulled it in the garage it ran fine and now this
You are under miss understanding this mower has a hydrostatic transaxle. It has a General Transmissions RS800P CVT transaxle.
Here is a trouble shooting guide.
RS800P Troubleshooting Guide
