S slimbo Member Aug 3, 2013 #1 happy outdoors 2 ,,,,does anybody have any ideas as for sharpening and adjusting blades on the either hs 85,,,, thanks 2 all n
Fish Lawn Pro Aug 4, 2013 #2 To sharpen them, I use the side of a thin cut off wheel to do the beveled edge only, you will have to move the blades several times to reach them all.
S slimbo Member Aug 4, 2013 #3 thanks for your interest...whats the angle you use,,,and is there a tautness of each nut of the blades??? i always thought they were adjusted right arent they self sharpening if you didnt any thin too goofy with them ,,thanks again
Fish Lawn Pro Aug 4, 2013 #4 I just try to keep it at the original angle as best I can, the nuts should be just snug enough to eliminate any slop, but not tight.
