Augustivus
- Aug 19, 2014
- 1
- 8
Hello all, first post and it's about my new-to-me HRM215. I got it off a guy on craigslist and he mentioned that it leaked some oil out the bottom. When I went to look at it, he filled the oil up to MIN (said it hadn't been run since the previous season) put gas in and did a few gentle pulls to circulate everything and gave a good tug and bam, fired right up. It sounded OK, not great, I tried it out a bit and everything was good enough, as I planned on some mild tuning later on. When I got it home I mowed the front yard (fairly small) and toward the end of mowing I noticed some smoke, not from the exhaust, but from the base of the top of the mower, in other words, from somewhere on the top of the deck. I parked it by the gate and in the few minutes it was by the gate it had leaked quite a bit of oil on the ground, enough to create a standing puddle. I don't want to damage the engine. Can someone point me in the right direction to fix this? My first guess is the bearing, item 27 in the picture below, does that sound right? Thanks for any help you can offer!
