rainman1442
- Jul 17, 2013
- 11
- 25
I have an HRC2163HXA Seriel No: MAKA-1069147 that has a leaky transmission. I replaced both transmission axle seals and wiped down everything. I filled up the case with Honda hydrostatic fluid. The next day the floor has a puddle of fluid on it and the housing is wet with fluid. Any suggestions where the fluid could be leaking from? It's not coming from the axle seals.
Thanks.
Thanks.
