Doesn't sound right.I picked up this used HR215, and I can't get over the fact that in order to engage the blade you have to have the self propel engaged as well. Is there a way around this? It seems like whoever designed this has never mowed a lawn before.
They don't side discharge either. Good engine, terrible mower.It seems like whoever designed this has never mowed a lawn before.
Which version?I picked up this used HR215, and I can't get over the fact that in order to engage the blade you have to have the self propel engaged as well. Is there a way around this? It seems like whoever designed this has never mowed a lawn before.
www.partstree.com
Could be the operator….....you can use blades with out using drive.
One lever with the yellow blade engage button. That lever is the drive lever......you can use blades with out using drive.
HR-215BL. Looks like someone removed the drive lever and hooked it to the blade lever.There should be 3 letters after 215. Please post those letters. Post a picture of your upper handle if you can.
