I just received a new set of Gator mulching blades. The blades are made by Oregon and appear to have the tips of the cutting edge (about one inch) tempered for hardness. This is great since most of the cutting and blade wear occurs at the tips. The problem is that the blades are about as sharp as a dull butter knife. Is that sharp enough ? I normally sharpen following the original angle to an edge which can cut skin. Am I over doing it? How sharp should a mower blade be?
