cpurvis
Go to the nearest university that has a school of engineering, seek out a Fluid Dynamics professor and ask him.
He will immediately begin spewing out Greek-letter named variables that explain the balance of pressures in painful detail. Painful, incomprehensible detail, but detail, nonetheless.
disclaimer: I do not know why. I can only fathom an "IF, AND, THEN" type guess.
IF the filter is on the suction side of the fuel pump, AND something is causing a restriction of flow between the fuel tank and the filter, THEN the filter is a space in which fuel can vaporize, causing a bubble.
Gasoline vaporizes readily. That's what we like about it. (Unless it vaporizes before it gets to the jets.) It doesn't take much of a pressure decrease to vaporize gasoline.
