how does the self propelled work on a troybilt model# 12AV5560711
Does your transmission have a cable on it ? If so, this lever that it is attached to engages the transmission when you pull or squeeze the lever on the handle. This cable also pulls back on the transmission to tighten the belt to turn the pully attached to the top of the transmission. Hope this helps !
