reynoldston
- May 23, 2011
- 5,705
I do not think I understand either. I looked up the various Toro drive boxes and even looked at my old one. They all have one thing in common. a sealed box with the gears enclosed inside shaped so that the cover holds the lube and the wheel shaped gear as it runs picks up the lube from the pool in the box and lubes itself and the gear that fits into it as well. According to the sheet it says on rebuild to fill the box with a few ounces of lube , coat the gears with lube as well, close the box and go mow.
If this is the case why in the world would would you want to take the gear cases apart, clean, install new lubrication every blade sharping? It just seem like over kill with a lot of problims. Do what possum said close the gear box and go mow.
